I would recommend you have a local avionics shop at least take a look at it and bench check the radio before sending it in as there may not be anything wrong with the radio, sending stuff to Garmin is an expensive way to troubleshoot.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
