Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
  #11
Old 05-06-2015, 09:22 PM
jclark jclark is offline
Originally Posted by Charles C View Post
I am looking for the best all around one. With WingX there are so many options and not sure which is the best. I was looking at the Clarity but it is a bit pricey at around $1200. I would like to have the Portability to take it to different planes when I am flying with friends and then mine.
I wouldn't have thought about skyrader but seems alot of perople are using it. I have looked a Levi too.
But like I said, there are so many out ther that is cabtible with WingX that was not sure which would work best and wanted to see what others were using.
Really not being picky here but really, "best all around" is in the eye of the beholder.
As mentioned elsewhere, I have tested a lot of these.
For sensitivity, it is probably between SkyRadar and iLevil 2 AW. THe older iLevil seemed to be not quite as sensitive as the SkyRadar and the new one is supposed to be more sensitive than the SkyRadar (I am testing and don't have the conclusive data yet.)
For portability, you have Clarity, DUAL, FDS and iLevil SW. The DUAL is smallest and does Bluetooth. The FDS *might* be lowest cost. The iLevil costs more but has more features, some of which might be worth a lot to some.
For price, at one time it was the FDS. Haven't checked recently.
Initially the Clarity, with some really cool features seemed to the hot ticket. Unfortunately, it was a bit too hot in the beginning so that had to do some fixing of that. Probably a NON-ISSUE by now (with the "tent" etc.). But it is really small with some really cool features. (For me, unfortunately though, since the did NOT make their data available vi the USB port, (I asked the for it just like I asked the others) it was not a player for what I was doing. (Nor the GDL 39. Nor the Stratus for same reasons.)
They ALL work.
If I read you right, lowest cost, smallest portability, works with WingX, the DUAL unit is probably closest to your spec.
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 05-07-2015, 06:46 AM
sapeloson's Avatar
sapeloson sapeloson is offline
I am using WingX Pro with my IPad and was wondering what people are using for their ADS-B receiver. I contacted ForFlight to see if the Stratus II would work with both knowing the answer that it wouldn't but I thought I would try. I was hoping it would so if in the future I wanted to switch to ForFlight then I could use the one reciever. So any input would be good on what you are using. Thanks.
While at SNF last month my partner attended a class on "Advanced I-Pad" use. He was amazed to find out that 90% of the folks attending the class used ForeFlight. We use WingX with the original Sky Radar and a very happy with it. Our desire was to add "syn vision". After much research he decided for us to go with the "I-Levil II SW". We will continue to use our WingX but, if we ever decided to change, it would also power ForeFlight. We have just started to fire it up so I can't tell you yet how we like it but, so far, so good..... I have Sky Radar hard wired in and have no plans to remove it "yet".... so for now we can hook-up to either...
RV-8
Phase 1 Flight Testing
Garmin IFR by Stein
Lycoming IO-360 (180HP)
MT 3 Blade CS
N84TH / Registered and GA sales tax paid! $@&!;:?)(!
N3159F C-182 @ KJES
Old 05-07-2015, 07:09 AM
Charles C's Avatar
Charles C Charles C is offline
That is very interesting that you can also use it with ForFlight. That makes me want to lean that way, due to if I ever have to/want to change I can use it for both and not have to buy another one to use with ForFlight. Thanks so much, Levil is located here in Central Florida so I might get in touch with them and see.
Charles & Fran Cantrill
RV-6A - SOLD
Piper Comanche PA-24-250 - SOLD
RV-7A - Sold
Progressive Aerodyne Searey - SOLD
Orlando, Fl.
Flying out of Grass Roots Airpark (O6FD)
ASEL Commercial/Instrument
Commercial Helicopter
Paid 2018 Dues Gladly Paid
Old 05-07-2015, 07:49 AM
Default iLevil
If you call there, ask for Ananda. She is who I have worked with the most.
The SW is the most feature packed portable in my view.
She is the General Manager, key software designer/developer.
Her dad is also the founder of the company (it does a bunch of other stuff too)
You might want to double check **exactly** what it means when the receivers say that there is current or future support for Foreflight. I am not **sure** but I seem to recall being told that it would not be for all the features that a Stratus provides. So if that is important to you, "look before leap".
Jamesd
James E. Clark
Columbia, SC
APRS
Old 05-07-2015, 07:59 AM
tommylewis's Avatar
tommylewis tommylewis is online now
Default my choice
I installed Pathfinder remote in both RVs because it works well with the GRT EFIS and Wing X on an iPad. They have worked very well for me.
Tom Lewis
RV7a N967BT 1900 hrs.
RV10 N143EB 960 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
Old 05-07-2015, 10:18 AM
Scrabo Scrabo is offline
Yes but neutered - apparently it uses FF Flight sim mod ( or whatever) to do it but no weather info is passed - so its a somewhat neutered hookup
see http://www.pilotsofamerica.com/forum...53&postcount=2
So hardly a reason to defect to FF from WingX
Old 05-07-2015, 08:15 PM
DennisRhodes DennisRhodes is offline
Kyle,
Actually on the list for one of the 600EXP. waiting on it to ship. Let you know when it arrives
DRRhodes
2020 VAF Supporter
RV9 N908DR
Old 05-07-2015, 08:45 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
Originally Posted by DennisRhodes View Post
Kyle,
I talked to Navworx today. Still a slight delay in shipping. I'm #74.
The price did just go up from $869 to $1049.
Still lower than anyone else for ads-b in/out.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 05-08-2015, 07:49 AM
sapeloson's Avatar
You're exactly right Scrabo,,,,, don't know how we missed that one... but, it's very good news. Now, I won't have to learn anything new.....
RV-8
Garmin IFR by Stein
MT 3 Blade CS
N3159F C-182 @ KJES
