Old 05-04-2015, 10:49 AM
von_flyer von_flyer is offline
Default Tricycle to Tailwheel conversion - paperwork?
I have been told that when converting from a tricycle configuration to a tailwheel configuration that the airplane must enter into a Phase 1 testing period.
Question: Does the airplane need to be inspected and by whom? DAR/FAA?
Question: Is a new registration issued since the aircraft type changed?
Question: How long is the Phase 1 period if required?
Thank you in advance!
John von Linsowe
Michigan
RV-7
Cessna 140
Old 05-04-2015, 02:43 PM
Greg Arehart's Avatar
Typically no inspection needed.
No new registration since the type has not changed (it is still whatever you originally designated it)
My phase I repeat was 5 hours.
That was my experience. I don't know if it is typical or not. Ask Mel.....
Greg
Greg Arehart
N 7965A
Old 05-04-2015, 03:08 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I would suggest you make a new weight and balance............as well as noting the changes in the airframe log.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-04-2015, 05:58 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
As others have said...
Greg, Dave Dormier, & I have been there.
My model # has not changed as you can call it what ever you want on the original AW.
I would have liked to change it to a 7 from a 7 A but there was push back from the FSDO.
FWIW, I don't think they totally understood the A designation
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 05-05-2015, 08:11 PM
N941WR's Avatar
N941WR N941WR is offline
The answer should be in your operating limitations.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-06-2015, 11:00 AM
gasman gasman is offline
Yes, this would fall under "major alteration" like prop or engine change.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
