Originally Posted by BillL
Maybe the regulator, but I would check the belt tension first. Then check the field wire for loose connections, including the plug to the alternator - look close.
Good luck!
I had not flown in a couple of weeks but got up yesterday and still notice the bus voltage low. Took the cowl off and found the belt was slipping. Unfortunately/fortunately I found the the bracket attaching the alternator to the engine boss had both lugs sheared completely off. Unfortunate because the fix is a little harder the just belt tensioning. Fortunately I caught this before any thing bad happened in flight.
Yet again another proof of my 3 step process to preventive maintenance:
1) pay attention to your instruments and notice when things change
2) ask the smart experienced people on this forum for suggestions
3) check out and trouble shoot based on step 2.
