Old 04-28-2015, 11:19 AM
Turbofan Turbofan is offline
Default Which rivets after sealing tanks?
Just cleaned slosh in 1991 rv4, pulled off entire rear bulkheads, MEK and soda blasted clean. I'm not the builder, but which rivets do I use to fasten rear bulkhead on? Looks like plans call for AN426AD3-3.5, but I wasn't planning on bucking these, besides, how could you unless I cut out access holes. Builder used blind rivets....any info?
Thanks, Tom
Cub/supercub builder/restorer
39 J3 on floats
53 supercub
47 pa11
91 RV 4
Old 04-28-2015, 12:23 PM
jpowell13 jpowell13 is offline
Default sealed blind rivets
Vans sells sealed blind rivets for that job. I think the part number you want is AD-42, but call them to verify.
Old 04-28-2015, 04:14 PM
wirejock's Avatar
wirejock wirejock is offline
Default Rivets
The rivets going through the z-brackets, baffle and into the ribs are blind. The rivets along the skin to baffle are the AN426AD3-3.5.
Unless the builder installed the baffle inside out but as you mention, there's no way to buck them.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 04-28-2015, 04:40 PM
acam37's Avatar
acam37 acam37 is offline
I just did the exact same thing on my '91 RV-4 tanks. I re-sealed every rib and stiffener along with sealing all the rivets. I bought new rear baffles and the above mentioned sealed AN4-4 countersunk rivets for the flanges from VANS. For the rivets along the backside, you can use regular blind rivets and seal the heads. No leaks on the flange or back rivets. You may find that if the fuel senders are original, they may need to be replaced. Mine were trashed.
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
Old 05-12-2015, 10:05 AM
Thanks ACAM....
Did you proseal, wait, then rivet, if so how long?
Or did you proseal and immediately rivet?
39 J3 on floats
53 supercub
47 pa11
91 RV 4
