  #31
Old 05-19-2015, 10:17 AM
nomocom's Avatar
nomocom nomocom is offline
Default Vaporization-Induced Overpressure
Originally Posted by Doug View Post
Boiling mogas is trapped between the fuel pump outlet check valve and the carby float valve, it continues to boil, the pressure increases to a point where the float valve is overcome .....
The pressure is only relieved by cooling the fuel line below the boiling point of its lowest temperature fraction, or by some active pressure relief mechanism such as a purge valve.
Exactly, Doug. Inadvertantly, the OP is doing a fractional distillation in the fuel line. The winter fuel has some components with low boiling points- makes your car start easier in cold temps, but also makes vaporization in a hot soaked fuel line more likely. And, as Dan said, the fuel pump springs sets pump pressure. Boiling fuel in the line and the resulting high pressure has the pump diaphragm pushed as far toward the crankcase side as possible and the spring is not stiff enough to move the diaphragm until fuel side pressure drops.
Interesting failure mode. One might call it vaporization induced overpressure.
The other mode is fuel starvation. No pressure and no fuel as in when all the fuel pumps have to work with is vapor, and the vapor compresses and doesn't work it's way through the system- vapor lock.
Both failure modes are a very good reason for a fuel recirc line. It may only be needed to evacuate the fuel lines post hot soak. When the airplane has continuous fuel flow and air moving through the cowl, the fuel may never get hot enough.
Stan
1990 RV-3 (now apart, upgrades in the works)
1959 C172 O-360
Old 05-19-2015, 02:47 PM
bret's Avatar
bret bret is offline
Originally Posted by Larry DeCamp View Post
I was thinking of a continuous recirc like FI uses. Calibrate the office to maintain 5psi with either pump. If you run the plumbing, why not?
One answer Is managing fuel level. You would need a fancy valve to coordinate the tank you are using��
This is what I have on my 70 OLDS 442! using a mallory 140 GPH 15 psi fuel pump near the tank, adjustable fuel presure regulator in engine comp, one line in two lines out on regulator, one to the carb and the other has a restricted return to tank, with engine running psi is adjusted to 7 psi. cool fuel recirc and when ign is off, all presure is released.
