Old 04-27-2015, 04:03 PM
ILikePike ILikePike is offline
Default Aerosun Vx and VP-X
I want to connect my Aerosun Vx landing/taxi lights to my VP-X using the VP-X wig wag feature as follows:
Left landing 5Amax per AeroLED to 5amp max pin on VP-X set to 5amps
Right landing 5Amax per AeroLED to 5amp max pin on VP-X set to 5amps
Both taxi lights 1.7A/each (3.4A) to 5amp max pin set to 5amps.
Does anybody think I may have nuisance tripping on the landing lights?
Does anybody sell 2C/#20SH for connecting these or should I just use 2ea 1C/#20SH for landing and Taxi
Jeff Green
2016 RV-8 #82985
1968 E33C Aerobatic Bonanza
Pleased to donate Dec 2019
Old 04-29-2015, 03:42 AM
KRviator's Avatar
KRviator KRviator is offline
Personally, I would wire them to a 10A pin and set it for 7A, but thats me and i have spare power pins. Though AeroLED's list them at 5A max, presumably that is steady state and I have no idea if there is a brief period where they may draw more than that 5A and trip the ECB.
By the same token, even though I have a VP-X in the -9, I do not know if a 5A circuit will trip immediately it goes from pulling 4.999A to 5.001A or if there is a short time delay.
If you have the pins spare, it might pay to use a higher current pin than have to re-do it later after finding out a 5A pin isn't quite enough.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 04-29-2015, 05:33 AM
Thanks for the reply.
I am running low on higher value pins, thus the question.
Jeff Green
2016 RV-8 #82985
Old 04-29-2015, 09:30 AM
cjensen's Avatar
cjensen cjensen is offline
You shouldn't see nuisance trips with those values.
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
