  #11
Old 04-30-2015, 09:05 AM
jchang10 jchang10 is offline
http://www.autofuelstc.com/approved_...airfames.phtml
I was curious, so on this page, i selected Lycoming for engine type. Notice that they dont list ANY IO engines. Only O engines. Thus, i dont think its displacement specific. Probably some other reason or marketing reason.
For Continentals, they do list IO-470 and IO-520. My guess is this has more to do with the marketing dominance of C182's and Bonanza's from the 70's maybe???
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
Old 05-01-2015, 02:13 AM
paul330 paul330 is offline
We've had this discussion in another thread.
Even 8.5:1 IO-540s are not Mogas approved even though a similar IO-360 is. They have, however, been approved for UL91 or 91/96UL available in Europe.
The bottom line is that under the US experimental category you can run what you like........
To get back to the question, I have standard 8.5:1 @260hp. I really can't see any reason to put in higher compression pistons or increase the power above that.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 05-03-2015, 05:01 PM
togaflyer togaflyer is offline
The engine shop Im considering recommended 9:1. He said its a great match with the IO 540. Said does not affect the engines longevity, gives a few more HP, fuel burn about the same. He does not charge any more for the higher compression jugs, so its not about making more money. I know the stock 8:5 gives the RV 10 more than enough for that platform, but I dont see a bump to the 9:1 a critical difference. Which was one of my concerns.
Old 05-04-2015, 03:14 AM
sailvi767 sailvi767 is offline
If you look at Rockets many are running 10 to 1 without any issues in the 540.
Old 05-04-2015, 02:10 PM
I'm not saying that you can't run an IO-540 with higher compression pistons but my point is - "what's the point?". You end up limiting yourself on fuel choices for more HP which, honestly, isn't needed.
It's a sweet aeroplane at 260hp.......
Paul
2019 Donation Made
Old 06-02-2015, 03:35 PM
Dorfie Dorfie is offline
Default Who makes them?
Which companies sell the 9:1 pistons or complete cyl assemblies?
Do you have to install cyl and pistons (complete assembly) from the manufacturer, or can you use pistons from one manufacturer and cyls from another?
Does Lycoming produce the 9:1 cyl assemblies?
Which manufacturers of cyl assemblies do you recommend?
Thanks.
Johan
Dorfie
RV10 Flying, N245JM
2020 dues paid with a smile
Old 06-02-2015, 05:14 PM
ColoRv's Avatar
ColoRv ColoRv is offline
Come to Denver. There is no such thing as to much power and many of us are running 10:1 including a buddy's rocket with a 540. No issues and at this altitude, no TBO reduction. At sea level...your mileage may vary if you run around wide open all the time like I tend to up here. Then again, at sea level I can't leave the big handle forward or I'm climbing the barbers pole.
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 06-02-2015, 09:09 PM
bob888 bob888 is offline
Default What about 10:1?
I believe my Lycon engine has 10:1 pistons. Anyone aware of problems with these?
Old 06-03-2015, 06:28 AM
Johan,
you can change the cylinders, which includes the pistons et all, to increase HP without much weight penalty. A friend has a -10 with 10:1 jugs and he claims he is in the 290 plus HP range. He calls it a poor mans turbo charge. Higher compression cylinders can also mean more wear and tear on the engine and could impact the longevity of the engine. I settled on the 9:1 because it was recommended by the engine shop that will be doing the engine build. Few more HP without being hard on the engine. If you get the XIO 540 from Vans, its a brand new stock engine vs a rebuilt. There is nothing wrong with a shop doing a rebuild, but make sure they use crank shafts etc that meets new specks. Cylinders etc should be new.
Old 06-03-2015, 09:05 AM
Default This where I need advice
I should explain better. I am replacing all 6 cyls on my engine that is being rebuilt. I am keen to go with 9:1 CR. I know there are different manufactures of cyl assemblies (ECI, Superior etc). In the past I have used Lycoming cyl assemblies exclusively, and have little knowledge about the other options. It seems that Lycoming does not produce 9:1 assemblies, but I might be mistaken. So I am asking for advice regarding choices and your experience with other manufacturers.
Thanks.
Johan
Dorfie
RV10 Flying, N245JM
