I heard an a&p man at the Light Sport Mechanic Inspector classes advise on using the special type of battery maintainer (which Odyssey makes and sells).
I got one and it is over there in the box.
ISSUE: how does an RV 12 driver access to the battery to maintain the battery by connecting the Odyssey charger/maintainer?
I have visions of drilling holes directly above the posts and then plugging the holes with rubber plugs.
I also have visions of running wire to the center port used to pull out the piano wire and then reaching and grabbing the newly installed wires which connected to the posts.
I am sure other RV 12 drivers have thought about this and accomplished this goal.
