Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 04-23-2015, 07:16 AM
sjarrell sjarrell is offline
Default Garmin G3X Touch Sun-n-Fun New Features?
Any new features being shown on the G3X Touch at Sun-n-Fun?
Thanks!
Steve Jarrell
Building RV-14A QB "Freedom"
N614US (June 14 - Flag Day)
Dues Paid - Gladly!
Old 04-23-2015, 09:48 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Thanks!
Hi Steve,
One of the new features you can see at SNF is touch screen radio tuning for GTN 6XX/7XX navigators integrated into the G3X Touch displays. This requires new GTN software that is not available yet, but the pre-release GTN software we are running in the kiosks supports this new feature.
Some of you have been following the new wiring guidance in the last couple of versions of the G3X Installation manual to incorporate bi-directional MapMX wiring between the GTN and a display. This supports this new feature when the GTN software becomes available.
As an example of this new flexibility, you could have your COM1 radio function being provided by your GTN 650 and your COM2 radio function provided by a remotely mounted GTR 20 radio, and yet the tuning interface on the displays is consistent and efficient.
Something else new at SNF is a new 3 display G3X Touch kiosk that is strapped for PFD1, MFD1, and MFD2 displays. Ask us to fly a coupled LPV approach with all those MFD screens setup to show the instrument approach on the moving map and a large geo-referenced approach plate (also showing the aircraft position) on the 10.6" wide MFD2 and we are sure it will put a smile on your face and instill confidence when you use it in real flight conditions.
Hope to see you there.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 04-23-2015, 02:11 PM
Thanks Steve. Unfortunately I'm not going to be able to make it down there this year.
Question regarding the COM feature... I'm currently controlling my SL30 from the G3X and that works quite nicely (except you can't do the freq. swap from the G3X, but that's minor.) Will the new feature allow the G3X to control both the GTN and the SL30 simultaneously?
Thanks, and have a great show!
Steve Jarrell
Dues Paid - Gladly!
Old 04-23-2015, 02:17 PM
LuisR LuisR is offline
Is G3X legal to fly IFR in IMC?
Regards
Luis
---------------------------RV-10---------------------------
Empennage. Complete Minus fiberglass and attach section. FOR SALE
Build Log N925LC (Reserved) YouTube
Old 04-23-2015, 02:20 PM
dweyant dweyant is offline
No
-Dan
Dan Weyant
RV-9A N96KD
Done and Flying 4/30/2015
Old 04-23-2015, 02:21 PM
bkthomps bkthomps is offline
Yes with an approved gps source such as the GTN or GNS
Old 04-23-2015, 03:07 PM
aaronboulais's Avatar
aaronboulais aaronboulais is offline
Default ADS-B request
Steve,
Is there a current or future interface for the G3X touch and the GDL-88 with the WAAS reciever. I could skip buying a GTN 650/750, and just go the route of the GDL-88, that would fit my mission much better than an IFR GPS.
Thanks for the help.
Aaron Boulais
Stuck in spam can land for now.....
Will build when I retire in 25 years
Donation Made 4/13/2015
Old 04-23-2015, 03:34 PM
Brian, Dan, thanks for the reply. So as long as the G3x is fed by certified receivers, it's legal to use in IFR?
Regards
Luis
Old 04-23-2015, 04:58 PM
Yes. Absolutely. Positively. Unequivocally.
When you're using the GTN (or any other certified Garmin GPS receiver) with the G3X what you see on the G3X is actually coming from the external source, and you control everything (flight plan, OBS mode, CDI source, direct-to, procedures, etc.) directly on the certified device. When in OBS mode on the GTN, or when selecting your nav course the course knob on the G3X can be used. You can also view the GTN's flight plan on the G3X, but you must change it on the GTN.
For VFR flying you can switch to the G3X's internal GPS, but I prefer to just leave mine set to the external device (GTN 650 in my case) so I'm using it consistently instead of going back and forth. Less confusing for my pea brain!
Steve Jarrell
Dues Paid - Gladly!
Old 04-23-2015, 06:36 PM
Steve, thanks for your reply.
Regards
Luis
