HS
On the HS there are four holes to enlarge later but they are there near the center of the forward spar. On the skin there are several to attach the fairing later. They are also there. I can't think of any not pre-drilled.
On the VS there are two not drilled to be drilled later.
Can you be more specific?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Reason: add text
