Old 04-14-2015, 02:41 PM
Weasel's Avatar
Weasel Weasel is offline
Default Ray Allen Trim Wiring
The Ray Allen stick grip trim switch system has individual single pole double throw switches used (one for up and one for down) to control the trim servo.
The switches are rated so that they can be used in a single (pilot only) control setup to handle the trim motor load without the need of a relay.
The documentation goes on to say that in a duel ( pilot and co-pilot) control system, the relays are necessary.
My question is why to we have to have relays with the duel control setup?
I have my trim wiring like this:
The Power symbol has a + on the top and - on the bottom....its hard to read.
Am I missing something?
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1600hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 04-14-2015, 06:24 PM
Mich48041 Mich48041 is offline
My first thought was what would happen if the pilot pushed up trim and copilot pushed down trim at the same time. Would a fuse blow? Then I studied your wiring diagram and could not see any way that there could be a short circuit, unless I am missing something. Even if the pilot pressed up while the copilot pressed down, or vice versa, the trim will not work, but there will be no short circuit. Did you design that circuit yourself? If so, good job! You might consider a trim-disable switch in case a switch gets stuck.
Joe Gores
RV-12 Flying
Old 04-14-2015, 06:30 PM
Weasel's Avatar
Yes I designed it and have operated it in the RV-10 for over 600hrs. No problems. I was working on one the other day and it refreshed my memory on the subject. Thought maybe there is something I am missing.
Weasel
RV-4 715hr Sold
RV-8 700+hrs
SERFI AWARDS
Old 04-14-2015, 08:19 PM
I redrew your electrical drawing as a downloadable pdf.
And I put your name on it to give you credit. Hope that is OK.
Would it be alright if I shared your circuit on Matronics AeroElectric List?
Joe Gores
RV-12 Flying
Old 04-15-2015, 05:35 AM
Weasel's Avatar
Thumbs up No Problem
That is fine with me. Hope it helps someone.
Weasel
RV-4 715hr Sold
RV-8 700+hrs
SERFI AWARDS
Old 04-15-2015, 07:58 AM
Joel, I posted your circuit on the AeroElectric List along with words of praise.
In case of a runaway trim caused by a stuck switch or suicidal copilot, the opposite
direction button can be pressed and held until the fuse or breaker can be pulled.
Joe Gores
RV-12 Flying
Old 04-15-2015, 11:12 AM
DaleB's Avatar
DaleB DaleB is offline
The only issue I see is if you plan to make the copilot stick removable. I am thinking of a DB9 connector for the right side stick... I'd need a jumper plug to take its place. Other than that, it looks good to me.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 04-16-2015, 06:19 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Another issue I see is that without the relays you can't isolate the pilot flying (PF) trim control from the pilot not flying (PNF) trim control. With relays you can deactivate the trim control of the PNF so that he can't accidentally change the trim.
Otherwise the circuit is excellent and keeps with the KIS (Keep It Simple) principal.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 05-09-2015, 11:50 PM
sglynn's Avatar
sglynn sglynn is offline
Default Trim wiring with VP-X
Check out Vertical Power. WIth it you don't need the relays and wiring is way simplier. This is just one of many benefits.
http://www.aircraftspruce.com/catalo...clickkey=12347
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 05-22-2015, 03:55 PM
Raymo's Avatar
Raymo Raymo is offline
A custom jumper plug could be used to bypass the co-pilot stick, installed or not.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
