Old 04-12-2015, 05:22 PM
prkaye prkaye is offline
Default Source for replacement brake pads for a -9A
I need new brake pads... mine are shown in the photo below. They are the Cleveland brakes that came stock with my -9A kit. I can't seem to find these on Vans site. Can anybody recommend a source for replacements?
Thanks!
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 04-12-2015, 05:31 PM
krw5927 krw5927 is offline
Search on Aircraftspruce.com:
RA066-10600-4K
Under $25 for all 4 pads plus rivets.
Kurt W.
RV9A
FLYING!!!
Old 04-12-2015, 05:47 PM
Super, thanks. I've never done this job before... would it be straight-forward with this tool? http://www.aircraftspruce.ca/catalog...clickkey=49907
Phil
RV9A (SB)
Ottawa, Canada
Old 04-12-2015, 05:51 PM
Yes, that's the tool.
Usually new pads come with brass rivets but check to be sure.
I would check your disk for any damage/scraping/gouging. Best to change the pads before any of the rivets make contact.
Old 04-12-2015, 07:15 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Check the EAA website. There's a good video describing how to replace brake pads.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 04-12-2015, 08:50 PM
n82rb's Avatar
n82rb n82rb is offline
from the looks of those you may have to replace the rotors also. inspect the rotors, the rivet metal to metal wear will have worn grooves in the disk.
bob burns
N82RB
RV-4
Old 04-12-2015, 10:43 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
Vans' do have them: http://www.vansaircraft.com/cgi-bin/...uct=brake-pads
The Rapco RA066-10600 equivalent are a bit cheaper and seem to do the job just as well.
The brass rivets are relatively soft and may not have damaged the discs, but you should replace them before they get that worn.
Old 04-13-2015, 06:26 AM
Thanks guys!
The rotors still look good... When i run my finger around them they feel smooth, except for a slight feeling of a groove/ridge in a concentric circle around one of the rotors. This is not a deep groove - not visible.
What is the risk of continuing to use the rotor? What is the potential consequence? Reduced braking effectiveness, or could it cause whole pad to break?
Phil
RV9A (SB)
Ottawa, Canada
Old 04-13-2015, 07:50 AM
pierre smith's Avatar
Default Bed the brakes
Phil, taxi around with moderate power while holding partial brakes to help "bed" them to the rotors. Braking will get better after a few uses during taxi and landings.
Most pads nowadays have a small slot on the end that is your brake wear indicator. Take a look at those with a flashlight when you air up the tires and you'll see what remains.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 04-13-2015, 08:47 AM
Mike H Mike H is offline
I have operated an old C-150 with rotors so corroded, grooved and pitted that I would'nt even want them on a boat trailer and they provided normal braking, although they would eat brake pads at twice the normal rate.
Be sure to not cause a brake fire when "bedding in" the new brake pads. On a piston single I would only perform 2 to 3 "aborted takeoff" type braking manuevers from 30-40 MPH to bed in the pads then let the brakes completely cool. On a heavier aircraft ony perform one high speed brake application between cool down periods. I have seen more brake fires from pilots bedding in brakes by riding around the airport dragging the brakes for too long, or to many consecutive "high speed" taxi brake applications than any other cause.
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
