Old 11-09-2006, 08:16 AM
Roadster Roadster is offline
Default RTV on Snap Bushings?
Is there any harm in putting a small filet of RTV around snap bushings to hold them secure so they don't vibrate?
I have a couple of snap bushings on my horizontal stabilizer that are a little loose when initially installed, and I think the RTV will help.
RV-10 empennage (h-stab in progress)
My KitLog Pro Website
Old 11-09-2006, 09:48 AM
Mel's Avatar
Mel Mel is offline
No problem at all. Just be sure to use aircraft grade RTV. Some RTVs react corrosively with aluminum. It should indicate on the tube if it is safe on aluminum.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-09-2006, 10:22 AM
cytoxin's Avatar
cytoxin cytoxin is offline
Default thats waht i did
worked like a charm]
William Weesner/ still kicking.
Old 11-09-2006, 10:38 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
An alternative that I'm using on some of my thin bulkheads is to replace the plastic bushings with rubber grommets. They hold in much more firmly and provide a firmer hold (and provide cushioning) for the tubing or wiring. They can be ordered from Spruce in many inner and outer diameters.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 11-09-2006, 12:55 PM
Thanks, guys. I appreciate the prompt feedback, since I'm trying to get the skins riveted in place today.
Mel, I'm using PermaTex Ultra Black, which is non-corrosive and safe for aluminum parts.
