Old 04-11-2015, 05:58 PM
SteveHRV7 SteveHRV7 is offline
Default Andair Gascolator O ring size
After inspecting my Andair gascolator during my annual and then reassembling it, I noiced I had a fuel leak between the body of the gascolator and the cap. On removing the bowl, I found the O-ring had ruptured. Reading the forums on this topic I see several post that list the O-ring size for the smaller internal filter. I need the inside diameter measement for the larger O-ring between the bowl and the cap. The size looks metric as posts list the ring size as 1.5mm thick. Neither ACS or the Andair site lists the O-ring specs. I can order from McMaster Carr if someone can tell me the inside diameter. Thanks!
Steve Houghton
RV7a
Okemos, MI
N807SH
Old 04-11-2015, 08:28 PM
gasman gasman is offline
Try your local hydraulics shop.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 04-11-2015, 09:46 PM
flyingriki's Avatar
flyingriki flyingriki is offline
Why can't you mic the spot the o-ring sits in if you don't want to use Spruce?
Spruce: Replacement O-Ring for GAS375 05-00704 $7.50
http://www.aircraftspruce.com/catalo...andairgasc.php
Andair is cheaper: http://www.andair.co.uk/product/o-ring-oro375/
