Originally Posted by N62XS
I've seen several installations on the outboard rib of one of the wings. It would seem easier to install out there instead of under the cabin floor pans.
Not really. I found it difficult to mount the servo solid. The P/O of my kit installed one on the end rib. It looked good, but I was able to make the rib/servo flex and was afraid that it would cause hunting. The fuse install was much easier for a solid installation. It only took me a few hours and that included fabrication of the bracket because I was too cheap to buy one. I bet it's an hour install with a bracket.
the -7 allows for an install near the bellcrank, but not the 6.
Larry
