IO360-A1D on an RV-7?
Hi everyone.
Can a IO-360 A1D, previously installed on a Christian Eagle, be installed on a RV-7?
My engine mount is dynafocal 1.
I'm asking because despite my internet search I can not find the answer to what the "A1D" means with regards to engine specifications.
I know it's a fuel injected, had a constant speed prop installed on the previous aircraft, but that's about it...
Will the A1D fit under the cowl of a RV-7?
Thanks for your help.
Alain.
RV7 (F-PRVZ), Tip Up, Aerosport IO-375, Dynon Skyview, VP-X, Day VFR.
Flying since June 2017.
