Old 04-08-2015, 08:33 AM
WA85 WA85 is offline
Default Need help with P/N for Horizon Instruments 336 series oil pressure gage transducer
I have an RV-6 that has a Horizon Instruments model 336 series digital oil pressure gage. It was indicating normally and then started displaying 300 psi instead of 85 psi. The transducer is suspect, however I contacted Horizon Instruments and they said they have no parts or data on the 336 series gages.
Does anybody have a line on where a replacement oil pressure transducer can be found for the Horizon 336 series digital oil pressure gage?
Old 04-09-2015, 07:13 AM
h&jeuropa h&jeuropa is offline
I found this link to the guy that supposedly designed the 336 series instruments.
http://www.tkes.biz/
You might contact him directly.
It is also quite likely that it is a standard VDO or Westach sender. Consult their online info and compare photos and part numbers.
Jim Butcher
Old 04-10-2015, 06:56 AM
Jim,
Thank you for the info!
Old 04-14-2015, 07:39 AM
I was able to contact Tom Kelly directly and he is coordinating getting the oil pressure instrument and sensor checked / repaired by Horizon.
Thanks again for the info, it just proves that you can solve almost any RV problem by reaching out to the folks on VAF.
