My RV-7A has a nice panel but it was put together some time ago.
The GPS is a Bendix King KMD 150. You can't get database updates (and when you could they were $245 per update). The system drives an auto pilot which is a TruTrack Digiflight II.
If you want to see a quick summary of panel it is on a short video at
https://youtu.be/g7kscPKzQRs
I am intending to have this plane for some time. I would like to have a panel which has a quality source which is likely to be WAAS etc. For example a GTN 635 from Garmin see
LINK is an expensive unit at US$10.4k (excluding fitting). Features such as XM weather are not of interest due to use in Australia and ADS-B needs to be 1090ES as Australia has opted for all aircraft, except those operating under the VFR in Class D airspace or in Class G below 10 000 feet to be at 1090ES.
Any comments suggesting the most appropriate replacement for the KMD 150 are most welcome.
Tim
Tim Moore
Cottesloe, Perth, Western Australia
Owner VH-PDM RV-7A (Slider, Superior IO-360, fixed prop)
See
www.vhpdm.com.au
