GAMI Vs. Airflow
erich:
Go with Don at Airflow. Aside from being probably the most knowledgable man on the Planet about aircraft fuel injection, he's a homebuilder too!
I had what I thought was a problem with my F.I. Servo, and since I live fairly close to his shop, I took it there to have them check it out. Kyle, one of his technicians checked it out on the airflow bench, replaced a small nut inside, checked it again on the airflow bench, gave me a graph of the fuel flow at different airflow rates, and checked the flow divider. Then, Don and his wife, Kyle and another Tech bought my lunch. Total bill-----$117 dollars and change! When is the last time you got out of an FAA approved repair station for 117 bucks.
Almost forgot this was a certified servo and flow divider. Bill would have been $20 less if he could have his part instead of a genuine Bendix part!
Mannan Thomason
RV-8 N161RL No. One Girl
