Guys... WEST epoxy details are here....
http://www.westsystem.com/frames/tie...usermanual.htm
Jerry is a bit quick with his 30 seconds of mixing...:^)
WEST says 1 minute minimum, and take care to scrape the sides...
Unlike some epoxy primers there is no blending time (induction time) needed after mixing.
Follow the manufacturer's instructions for the best results....
gil in Tucson EAA Technical Counselor
If it's your first time using any product, do a test sample first... don't test on your project if at all possible....
