Old 04-03-2015, 12:00 PM
Guilhermepilot's Avatar
Guilhermepilot Guilhermepilot is offline
Default mixture lever touching cowl
I have learned many guys had this issue, mine is inverted up position and is touching, I read that it can be repositioned, maybe if I get it 15 degrees behind actual position on full rich. Anybody here did this way? I saw many putting it upside down and cutting FAB, or making a hole on cowl, but this option in my opinion is the worst
VI superior IO360 Silver hawk fuel system
Guilherme Plassmann (Brazil)
RV7A (Mr Flame) slow kit S/N 74285 Finished 04/14/15😀😀😀😀flying
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
LR30,PRM1,C560,C510S,HS125,B350 FAA/ANAC Pilot
Donation made 2016
Old 04-03-2015, 03:54 PM
I had an email from precision stating that are off set as well strait levers avlb, also it is ajustable, but I need to figure it out if my mixture cable will accept it in terms of lengh
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
Donation made 2016
Old 04-03-2015, 07:15 PM
clam clam is offline
Default maybe a mixture alternate rotation direction ?
Not sure of your complete issue, but Precision does make a model of the Silverhawk FI servo where the mixture lever rotates clockwise for idle cutoff. This is normally used on vertical induction engines. Might be worth looking into before you modify too many other parts.
RV-8 KFYE
Memphis, TN
donation given
Old 04-04-2015, 09:56 AM
ka6dan ka6dan is offline
I assume you have the offset lever. I had the same problem. Switched to the straight lever and it clears the cowling. I did however have to modify the air filter box to accommodate the straight lever. Made a small three sided box that is up against the air filter. It all turns out to have minimal but adequate clearances. Hope this helps
Ka6dan
RV9A
Phase I @ X35 is complete
Paid My 2020 dues. 😃
Old 04-04-2015, 05:41 PM
yes the straight one should solve
thanks
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
Donation made 2016
