Originally Posted by rmartingt
I'm fairly sure you don't need dual GPS units to fly an LPV approach... a single 430W (among others) will do the trick.
Correct. A single TSO 145/146 WAAS GPS unit is all that's required for LPV approaches for part 91 ops.
RNP and RSVM don't apply to RV's -- those get into performance, naviagtion, and certification criteria that are generally outside the realm of piston driven, E-AB type aircraft.
As far as I can tell, FIKI is a gray area for E-AB certificated aircraft. IOW, if you were to equip your E-AB with anti-ice systems and run some tests, the FAA isn't going to come out and slap a "FIKI approved" sticker on it an call it good.
One thing I noted is you captured a wide range of requirements on your list, not all of which apply depending on whether the aircraft in question has a standard certification or is E-AB, has one seat or many, or is operated under part 91 or part 121/135.
