Old 04-01-2015, 05:57 AM
blueflyer's Avatar
blueflyer blueflyer is offline
Default Rubber Duckie Antennas OK for bench tests?
Is it OK to attach rubber duck antennas to my radios in my panel in order to conduct a safe bench test?
Old 04-01-2015, 06:17 AM
ColoRv's Avatar
ColoRv ColoRv is offline
Are you really going to trust opinions on the internet when talking about equipment this expensive? I would call the manufacturer.
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 04-01-2015, 06:57 AM
Walt's Avatar
Walt Walt is offline
Handheld radios put out about 1-2 watts, panel mount average is 10 watts. Bottom line, I wouldn't recommend it.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-01-2015, 08:59 AM
n82rb's Avatar
n82rb n82rb is offline
given the backgrounds and reputations of some of the people on this forum, yes i would.
Old 04-01-2015, 09:02 AM
For bench testing radios, I would use a "dummy load" rated for the power and frequency range of the transmitter.
They are not overly expensive but if you ask at a local EAA chapter or if you know any local HAM radio operators, you may be able to borrow what you need.
Old 04-01-2015, 09:06 AM
blueflyer's Avatar
Thats what I needed to know. Thanks again for the quick and thoughtful responses.
Old 04-01-2015, 09:42 AM
fl-mike's Avatar
fl-mike fl-mike is offline
shoot me an address via PM and I'll send you one of my excess RF dummy loads. Still have a few.
Mike W
Venice, FL
N164WM
Old 04-01-2015, 10:27 AM
blueflyer's Avatar
Mike, a very big thank you!
