Old 11-07-2006, 07:36 PM
scard's Avatar
scard scard is offline
Default instrument pitot/static thread sealer or dry?
Is any kind of thread sealer or other compound called for on the (plastic) NTP threads of the pitot/static connections on instruments? I'm thinking these should just be dry but would like confirmation.
Scott Card
CMW E-Lift
Old 11-07-2006, 08:36 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I've always installed them dry Scott, but I can't cite any documentation that says that. Never had any leaks I coudln't solve with a little more tightening...
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-08-2006, 07:10 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
The plastic fittings (the pipe thread part) should be dry and only slightly more than hand tight. I think the tube and nut end may bottom out on most types. Any thoughts on that out there?
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
