I always weight them empty.
According to the Bible (43-13, chapt 10-14)...
Drain the fuel system until the quantity
indicator reads zero or until the tanks are
empty with the aircraft in level flight attitude,
unless otherwise noted in the TCDS or Aircraft
Specifications. The amount of fuel remaining in
the tank, lines, and engine is termed residual fuel
and is to be included in the empty weight. In special
cases, the aircraft may be weighed with
full fuel in tanks provided a definite means of
determining the exact weight of the fuel is
available.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
