Westach hall sensor
My Westach hall sensor that is mounted to inside port on my right mag became unpotted and failed (no rpm indication) at 250 hrs. I bought a same type replacement sensor, $75, and installed and rpm is indication is working again. I hope this is not a recurring problem with this sensor. I gorilla glued the old sensor and pushed it back in place as a backup. I don't know if it will ever work again though.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
