Old 03-26-2015, 07:30 PM
Charles in SC Charles in SC is offline
Default Wire crimper question
This may not be the place to ask this but here goes. Is there an economical crimper for #6 wires? The Van's wire kit that I got needs an end crimped on it at the relay end. I would like to be able to make the nice double rolled crimp. I also need this for another project.
Thanks in advance!
RV 7
Old 03-26-2015, 07:58 PM
rv7charlie rv7charlie is offline
propane torch, solder & heat shrink.
If you insist,
http://www.bandc.biz/impactcrimptool.aspx
or
http://www.harborfreight.com/hydraul...ool-66150.html
Or take the prepped wire & connector to your local welding shop, along with an assortment of donuts (welders don't eat pastries).
Charlie
Old 03-26-2015, 08:01 PM
blueflyer's Avatar
blueflyer blueflyer is offline
I have the harbor freight crimper linked above. I am pleased with it.
Old 03-26-2015, 08:22 PM
Thanks for the link but that one does not make the pretty rolled crimp.
RV 7
Old 03-26-2015, 09:07 PM
BillL BillL is offline
This one makes a pretty crimp, but I don't know if they are still in business.
http://www.theterminaltool.com/Home_Page.html
I took the HF crimper back and got a larger one off of eBay. The hexagonal dies don't align well.
Bill
RV-7
Lord Kelvin:
Old 03-26-2015, 09:33 PM
pilotkms's Avatar
pilotkms pilotkms is offline
Default STEIN
Check with Steinair. ADVERTISER & SUPPORTER here on VAF. $48 & does an excellent job. very professional.
http://www.steinair.com/image/Produc...RIMPER%20L.jpg
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
550+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
Old 03-27-2015, 08:44 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
Charlie
With full instructions here courtesy of AeroElectic Bob -
http://www.aeroelectric.com/articles/big_term.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-27-2015, 08:48 AM
Auburntsts's Avatar
Default +1
I did the solder method on my "big" wires per Bob's how-to linked above -- turned out great and was a cheap method to boot!
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 03-27-2015, 11:24 AM
MarkW's Avatar
MarkW MarkW is offline
A crimp for a #6 should be solid copper and this size/kind of fitting will not roll like the smaller ends.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 03-27-2015, 12:10 PM
It's funny that nobody has mentioned using a swaging tool to accomplish this task. Nicopress sleeves come in a number of different diameters, some of which are nearly perfectly matched to an ideal swaged diameter of copper wiring terminals. I've used a Nicopress tool for this purpose many times over the years and have never had a joint fail or otherwise need replacement.
