03-25-2015, 08:29 AM
Originally Posted by patterson
I have a Lycoming with about 50 hours on it that is behaving very badly.
It is cyclical roughness, happening every few minutes. It begins with roughness, followed by lower RPM's, higher EGT's (all) and a feeling as if it is self leaning! Fuel flow goes down by 2-4 GPH too (11+ down to 7 or 8 and EGT's rising to Peak). A few seconds (20-30) and it cures itself. Then in a few moments, it all begins again.
Isolating the mag does not improve or make it run worse or better. Same for the one Lightspeed II/Hall effect I am running. Feels like the engine is about to give up, then it takes a breath and goes on normally for a few minutes. It will run hard and even overspin the CATO prop (it's underpitched right now), then runs very poorly... like I need to find a place to land. Goes from 2750 down to 2450, and then, slowly, back up again. Scary!
Because if "feels" like a fuel issue, I traced everything in the (new) AFP 150 for loose fittings or fouled filters.... no joy. Cleaned everything and tightened fuel fittings and no change in the way it runs. Takes a few minutes on the way to altitude before it starts in, then never corrects. Same issues regardless of altitude or RPM. Could the mag be working intermittently? Hall Effect? If so, you would think isolating them would make it quit altogether, but it doesn't change anything except the EGT's go way up, and then I get nervous and switch back to both.
Any thoughts you may have are much appreciated.
Ron
RV-4
The AFP150 may have to go back to Don for a bench check.
The fuel vents need be checked for obstruction.
The drop in fuel flow and increase in CHT confirms it is a fuel flow problem. I wouldn't fly it again without having the AFP150 checked.
The only other issue could be fuel vaporization somewhere before a pump. It won't vaporize downstream from a pump at 25-30 psi and flowing but it could be vaporizing just before a pump. This could be an issue forward of the firewall going to engine pump, but it should not be a factor if the electric pump is aft of the firewall and operating.
Are both pumps on when it happens?
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
03-25-2015, 08:36 AM
good ideas
Thanks for the troubleshooting ideas.
Yes, it did start abruptly... about 10 hours after install of FI.
It happens on either tank so probably not a fuel line vent.
Don at AFP thinks it could be sucking air. I will try the Tygon tube to see if I can see bubbling.
I'll check the mixture arm for tightness at the servo or play in the cable.
I've re-tightened all the fittings, but never considered they might not fully seal and could suck air but not leak gas. Is this very common?
Tried boost pump many times... no change
Ron
03-25-2015, 08:44 AM
Air leak
I don't know how common this is. I'm the only one anybody I know has had it happen to. The fittings on the fuel valve are blue anodized so I could not see any fuel residue. Once I got the valve out I could rub a little blue dye at the pipe thread on the valve. Removed them and resealed them problem solved. They were originally sealed with PTFE lasted 700+ hours before failure. I used Permatex 2 this time. Oh yeh take a picture of the position of the fittings before you take it apart. Ask me how I know.
Horse Power is good, more is better and
Too Much is Just Right
RV 8 Super charged Barrett IO-390
Dues paid 2020
Dan "Nordo" West
03-25-2015, 09:22 AM
I had a similar issue. No fuel leak but a rough running engine on occassion. In trying to isolate where the issue could be. I installed a fuel line from a gas can and affixed it to the top of the motor mount so it could gravity feed to the mechanical pump on the engine. Engine ran great so i knew it was in the fuel lines somewhere. In my RV8 the fuel filter is vertical and on the gear tower. the top nut on the fuel line coming out of the filter was not 100% sealed and would suck air breaking the vacuum in the fuel line. Sealing this connection took care of the issue.
ZGood luck finding the issue. I know how gut wrenching it can be when something is not right.
Tom Ellis
New Lenox, IL
USMC
Tech Councilor
Flight Adviser
RV 8, N812TE- flying
RV-10, building
RV-12- building
R-22, R-44 flying
Titan T-51- Sold
Rotorway 162F flying
AVID MK IV- in paint
03-25-2015, 10:13 AM
I had a similar issue, though it didn't have as big of an RPM drop. It turned out to be a spark plug that had a cracked insulator around the sparking probe. I was pretty lucky it didn't break apart and damage a valve. We found it with a very close visual inspection of each spark plug. Although, this might not be your issue since it happens on both mags. But you could also have multiple issues creating a compounded problem ... it's worth a check.
Mike Smith
RV-6, 160hp, fixed prop
Grass Valley, CA (KGOO)
03-25-2015, 10:15 AM
Sucking air and not leak fuel, seen it many times at work.
03-25-2015, 11:35 AM
VAF Moderator
Originally Posted by JonJay
I have done this. The only thing I can add is that it is no fun standing behind a prop spinning at 1500 rpm. Obviously, tie down and chock, and it wouldn't hurt to have a trusted buddy at the controls. Scary!
Thats why we have GoPro cameras.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
03-25-2015, 01:09 PM
Sucking air
I had air intrusion with electric fuel pump on and no fuel leak. Wasn't so bad it caused engine symptoms. Discovered it after attaching tygon tube on outlet of AFI fuel servo. Problem solved by putting that super sticky fuel lube goop on all the fittings between the selector valve and inlet to AFP filter.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
03-26-2015, 06:44 PM
If the problem only manifests while in the air, check your quick drain on your gascolator if you have one. I had one that would let air in at high power settings (on take off). I have heard of one other that leaked air at higher airspeed partially due to ram air flow(similar to pitot pressure) over a less than ideal drain tube exit angle / location.
03-27-2015, 08:31 AM
Add these to the fittings and re-test... any gaps letting air but not fuel leak will be microscopic.
http://www.aircraftspruce.com/catalo...37fittings.php
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
