Old 03-24-2015, 01:28 PM
Iluke Iluke is offline
Default F-601Z Aux fuel firewall doubler
I'm working on my firewall and about to fab the F-601Z fuel pump doubler. I've seen some posts that suggest it should be installed slightly off what the plans suggest. Apparently the stock orientation results in too sharp of a 90 needed in the fuel line?
Has anyone experienced this, and if so, wwhat if anything would you suggest I do different than the plans?
And yes, I know I don't need the F-601Z if I'm going to use a fuel injected engine. My problem is that at this point I don't know what engine I'll be using so I want to keep my options open. It seems easy enough to blank off the two penetrations if I end up not needing it.
thanks
Ivan
Ivan Luke
Hope Valley, RI
RV-7 SB
Just hung the engine!
2020 dues paid
