Originally Posted by JBPILOT
you need to burp it, then check level. I would suggest Aeroshell Sport + 4 only. I think it is the only oil now recommended by ROTAX.
Definitely correct about burping first. In general, the Aeroshell Sport is a good first choice. When I did iRMT training in January, the Aeroshell Sport Plus 4 was recommended when using Auto fuel and only occasional 100LL.
Mobil 1 Racing 4T is also recommended if but only when using Auto Fuel 100% of the time.
Pennziol Motorcycle Oil is recommended if using 100LL all or most of the time. In this case, oil needs to be changed every 25 hours.
In fact, when using 100LL more than 30% of the time, oil should be changed at 25 hours and Oil tank should be removed and cleaned.
