Old 03-22-2015, 03:37 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default 9a-9 conversion question
I am considering a conversion from my
9a to a 9. I have finished my cowling for the 9a.
Will I be able to use the same cowling for the 9 when I change out the engine mount? Has anyone done this conversion that may be
able answer this question?
Al Girard, Newport, RI
N339AG
RV-9
Old 03-22-2015, 03:49 PM
scard's Avatar
scard scard is offline
It is the same cowl. Just glass up the slot you cut in it for the nose gear leg and rock on.
Scott Card
CMW E-Lift
Old 03-22-2015, 04:57 PM
cajunwings cajunwings is offline
Default Convert to 9
Not flying yet but have done most of this conversion. I agree with Scott, same cowl. If you don't want to glass up the nose gear slot you could make a sheet metal cover and use same nut plates.
Don B
RV 9 Rebuild in Progress
Old 03-22-2015, 08:50 PM
flyboy1963's Avatar
Default options?
....or make it larger, and perhaps it could become a cowl flap?
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 03-23-2015, 06:32 PM
curtis's Avatar
curtis curtis is offline
Exclamation Like my NLG
http://youtu.be/TTUQyEr-sg0
Couldn't resist!
RV-6A Slider
550 hours +
Build it light and cheap
Old 03-24-2015, 08:24 PM
Greg Arehart's Avatar
Been there, done that. Yes the cowl should fit fine after the conversion, though you will have to modify to fit the new gear legs coming out of the corners.
Greg
Greg Arehart
N 7965A
