Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
  #11
Old 04-02-2015, 06:29 AM
Jesse's Avatar
Jesse Jesse is offline
I assume any output should work, but I don't know for sure. They are high density pins.
Jesse Saint
Old 04-03-2015, 07:29 AM
TTU_RV7's Avatar
TTU_RV7 TTU_RV7 is offline
Default Check Message
Gary,
PM Sent. I think you need to check the message protocols as well.
Mike
Mike "Mikey" Frazier
RV-7A Kit Quitter Devoted to family winner Now looking at completed RV-7As
"The Road Goes On Forever and the Party Never Ends" -- Robert E Keen
Old 04-03-2015, 08:45 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Any one of the serial output pins will work. The format is software configurable in the GTN.
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 04-04-2015, 10:07 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
You should also check out the King KT74 s/es transponder. It is approved for use with the 430/530/650. I am using this and it works great. It has a much nicer looking interface and is close to the 327 depth and same height as the 327.
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 04-06-2015, 09:10 PM
b432291 b432291 is offline
Will Dynon be coming out (by end of 2015) with a TSO compliant (Not saying certified) GPS to allow their Mode S transponder do ADS-B OUT?
Old 04-06-2015, 11:05 PM
The gps position source used for ADSB-out does not need to meet any TSO requirements. It has to meet 91.227.
Old 04-06-2015, 11:10 PM
Did you have to install a pressure switch in the pitot line to do the air-ground switching? Any trouble getting the installation manual from King?
Old 04-07-2015, 02:05 PM
OK, so let me rephrase. I have a skyview and the skyview Mode-S transponder. I can only do ADS-B out today if I hook a 91.227 compliant GPS to the transponder. If the skyview already has a GPS, why do I need to buy another GPS (which would bring the GPS count in the plane to four total...)?
Will dynon be supplying a 91.227 GPS for the skyview system anytime soon???
Old 04-07-2015, 02:12 PM
Krynn Krynn is offline
As I understand it, you don't need a 91.227 compliant GPS until 2020.
Old 04-07-2015, 02:16 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
In 2020 you have to use a 91.227 compliant position source, until then you can use the SkyView GPS to get ADS-B IN data to whatever ADS-B receiver you may currently have.
Because, I assume, none of them are 91.227 compliant.
Not that they have announced.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
