Old 11-06-2006, 10:52 AM
TerryWighs TerryWighs is offline
Default elevator/rudder bearings/attachments
I am wondering if the rod bearings require any lubrication/oil??? or are these parts designed to function without external lubricaiton??? Also, are the bolts which pass through the bearings protected by adding any lubricants???
RV-8 builder..."Reindeer Man"
Fairbanks, Alaska
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage kit 90% done...
Old 11-06-2006, 11:00 AM
prkaye prkaye is offline
Default corrosion protection
Related question: for the rod-end bearings that we get with the empennage kit, these may sit around for years. Will the threads rust? Is there any harm in squirting some oil in the threads before putting away for storage?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 11-06-2006, 02:19 PM
DanH's Avatar
DanH DanH is offline
Been a while since I looked up the specs in the catalog, but...
(1) A drop of oil on the ball at annual is a good idea.
(2) As I recall the shank is plated, and so the threads shouldn't rust stored indoors. I have some that are 30 years old. However, spraying some Rust-Lick (good stuff) can't hurt a thing.
Dan Horton
Old 11-06-2006, 03:07 PM
Thanks Dan...
Fairbanks, Alaska
empennage done
Wings done
