No fuel flow reading with Red Cube
For 2 days I was getting GPH fluctuations then in the 3rd had zero read out of the EI fuel flow gauge
I replaced the transducer but no change
Called EI went thru the troubleshooting checklist
(Red wire has power, white wire sending impulse, connections look good) but still no flow reading but otherwise display of gauge fine
Tried different connectors as well as just connecting the bare wires together from the transducer wires to the instrument wires in case the supplied connectors from EI was the problem
No change
Ei thinks it is a connection problem not the transducer but I can't find a connection problem
While running the engine I may sporadically get a .4-.6 readout at a high rpm
Otherwise engine running fine
Electrical problem solving is not my forte so I thought someone may have been in this situation to help me out?
Thanks!
Craig
Craig Jace
N133JL
RV-6A
Dual EFII
Exempt But Dues Paid
