I don't recall any place on the registration form asking for prop S/N.
The only S/N required on FAA form 8050-1 is the aircraft serial no.
The only place the prop S/N is asked for is on the 8130-12 (eligibility form) and you don't need that until you apply for airworthiness certificate.
In that case you simply put "none".
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
