Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 03-13-2015, 11:15 PM
gmcnair's Avatar
gmcnair gmcnair is offline
Default In Cockpit timing adjustment on Lightspeed ignition
Hi Guys,
I installed a cockpit potentiometer as per Lightspeed on my Plasma 2+ ignition. If anyone has done this I have a quick question. Is the Full Retard Timing position at 0 ohm or the 9.27 ohm position I'm getting from the potentiometer.
Regards
Gary
Thailand.
RV-8
HS-GMC
Nok Field
Chiang Mai, Thailand
