Originally Posted by Captain_John
There are no user adjustments on the headset.
Don't say so. At least 30G has microphone gain control just where microphone capsule is located (under the soft stuff). It's not mentioned anywhere but can be easily adjusted if needed -- our headset microphone was set very low level and micrphone gain had to be increased to make headsets usable.
If I recall correctly, also 20G has same kind of control for microphone gain. However I don't see, how this would solve original problem.
