Old 03-10-2015, 08:15 PM
DHeal DHeal is offline
Default How to make a 0.75" Hole in Stainless Firewall?
I need to make a 0.75" hole in the "already installed" stainless steel firewall on my RV-12. What would be the best way to make this hole - drill bit, Uni-Bit, punch, etc? I prefer to not bleed. Thanks for any useful tips!
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 03-10-2015, 08:22 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I have had good luck with a Unibit.
So has this guy https://www.youtube.com/watch?v=ORXqvOevRbA
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-10-2015, 08:26 PM
BillL BillL is offline
Drill Bit -NO - NO - NO
Unit-bit - OK
but make it one step undersize and then use a carbide burr or sand out to size. Be very careful - - don't touch it until sanded to final smooth.
If the undersize looks good, no distortion tearing etc. then go for the next one, otherwise use method above.
Best - punch! - still have to sand the burr
YMMV
Bill
RV-7
Lord Kelvin:
Old 03-10-2015, 09:14 PM
terrye terrye is offline
Default Rotacut sheet metal hole cutters
I didn't have much luck with a unibit. Caught just as it was going through.
Much better luck with a rotacut sheet metal hole cutter. Back up the inside of the hole with a piece of plywood.
http://www.hougen.com/cutters/sheet-...e-cutters.html
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 03-10-2015, 10:01 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Yes... Yes... Yes and AMEN!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 03-11-2015, 04:48 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default SS hole
The rota cut style will work. I used a high dollar carbide unit ( my brother in laws) and it was beautiful. If you only need one hole, try a cheap one.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 03-11-2015, 05:05 PM
gasman gasman is offline
Hi David, Just did one in my six..... Used a uni-bit, but started with a standard drill bit for the pilot hole. Center punch... drill 1/8"... then 1/4" then uni-bit. Used a battery drill motor on low speed-high torque and used a little cutting oil. Go slow and use firm pressure to keep it cutting. Did a nice job.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 03-11-2015, 06:50 PM
spatsch spatsch is offline
Knock out punch works great just a bit expensive if you only need one hole....
Oliver Spatscheck
RV-8
N-2EQ
http://www.spatscheck.com/oliver
Old 03-11-2015, 07:07 PM
The SS might be too thin to punch without adding a layer of scrap to the area.
Old 03-11-2015, 07:40 PM
I used the 1 inch punch from aircraft spruce:
http://www.aircraftspruce.com/catalo.../knockout2.php
As said worked great just needEd to debur the edges a bit when done.
Adding a layer of scrap sounds like a good idea just to be sure... .
Oliver Spatscheck
RV-8
N-2EQ
