In the dark - of course
Find a flat surface with a wall. An apron in front of a hangar is perfect.
Move the aircraft up to the wall, pointing directly at it.
Turn on landing lights and mark centres of light beams on the wall with masking tape.
Pull plane directly backward 30-40', still pointing at wall.
Adjust centre of lights to point at tape marks you put on the wall previously, you could also aim them a little low depending on your normal approach attitude...
With a taildragger you might aim the taxi lights quite a bit lower than the landing lights. With a nose wheel about the same should work.
Fly it and re adjust if necessary...
Howzat?
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
