Old 03-09-2015, 03:32 PM
MikeyDale's Avatar
Default 25 hr flight test period
I have a pre owned Lycoming IO 360 B1E and a new Hartzell HC-C2YR-1BFP/F7497-2 I purchased from Vans. I have replaced the rear facing sump on the B1E with a Superior cold air sump. Assuming all AD's were complied with on the engine and prop, would I be eligible for the 25 hour Phase 1 test period ? Where do you look to see if this engine/prop combination appears on a type certificate?
Thanks in advance!
Mike Hillger
RV 7 FLYING SINCE 4/2015!
Garden City, Texas
Dues Paid
Old 03-09-2015, 04:31 PM
AX-O's Avatar
AX-O AX-O is offline
If you have and electronic ignition, the answer is no.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 03-09-2015, 07:34 PM
MikeyDale's Avatar
Dual Bendix Mags
Mike Hillger
Garden City, Texas
Dues Paid
Old 03-09-2015, 08:19 PM
N941WR's Avatar
N941WR N941WR is offline
As I understand it, the engine AND prop have to be certified together to get the 25 hours.
I do know of one builder who used an engine and prop out of a damage RV and received a 25 hour Phase I because the engine and prop came from a previously certified airplane.
That said,40 hours will go by fast and will give you just enough time to perform all the tests.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-09-2015, 08:47 PM
n82rb's Avatar
n82rb n82rb is offline
I got a 25hr phase one from the faa with an electronic ignition. Guess it depends on the inspector.
Bob burns
Rv-4 n82rb
Old 03-09-2015, 10:08 PM
AX-O's Avatar
Bob burns
Rv-4 n82rb
extra words
Axel
Old 03-10-2015, 07:17 AM
Mel's Avatar
Mel Mel is offline
Keep in mind that FAA inspectors do NOT have the authority to "override" the rules. If an inspector did something wrong, your airworthiness may not be valid.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-10-2015, 10:42 AM
MikeyDale's Avatar
Thanks Mel. Do you know if replacing the sump of the B1E makes me ineligible for the 25 hour deal?....I have no problem with the 40 hr phase 1 but the restricted test area will probably be confining where I'm at with so few airports so spread apart.
Mike Hillger
Garden City, Texas
Dues Paid
Old 03-10-2015, 10:51 AM
Mel's Avatar
Mel Mel is offline
Probably! Unless you can find a certified aircraft that used that particular sump.
