Old 03-09-2015, 08:34 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Default Aerosport Landing Light Installation
I just finished the installation of the Aerosport Landing Light Kit. The most difficult part was the paint. Unfortunately the light bezel intruded on the white as well as the blue paint, so it took a little more effort to match the paint. I used the Baja Designs 4 light super-bright LED. While I haven't tried it at night yet, with the hanger totally darkened, the nose light now makes the 75W wing tip lights look like a small flashlight! Can't wait to get it out at night. I was always hesitant to fly trips at night because of the poor lighting of the wing tip lights. I attached a couple of photos of the installation.
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 03-09-2015, 09:48 AM
Thanks for posting, Bill. Would welcome a pic or two of the inside, particularly how you mounted the Baja lights. (Please, pretty please!)
Old 03-09-2015, 11:32 AM
I took a bunch of photos of the inside, but somehow between the hangar and home I lost the SD card. I took the above photos with my iphone. Next time I have the cowl off I will take some photos. What I ended up doing with the wire is using a #18 shielded wire, the Baja light only draws 3.5 amps. I already had heat shield stuck to my cowling, so I used some leftover pieces and just ran a 1 inch wide strip of adhesive heat shield with the wire centered in the middle up to the hinge line, then down the hinge line to the firewall where I used a molex connector. The wire is completely hidden and protected from heat. I will post an inside photo when I remove the cowl next.
Bill Peyton
RV-10 - 1125 hrs
N37CP
Old 03-09-2015, 12:04 PM
Thanks, Bill. I'm looking at cowl light options and the Baja is high on the list, as is the Rigid Duelly D2. More light, less watts... but more money. Ugh, here we go again! LoL
Old 03-09-2015, 07:01 PM
Ivan Kristensen's Avatar
Ivan Kristensen Ivan Kristensen is offline
Default Cowl light
Here is a link to my Phanfare photo album where I have a number of pictures stored of this installation.
http://www.ivankristensen.phanfare.c...geID=226700105
Ivan Kristensen
Guelph, ON. Canada
RV-10 (C-GMDV) 1355hrs.
Dual GRT 8.4" HXr EFIS, VP-200, TT A/P, Avidyne IFD440, uAvionixX ADS-B out, Sky Radar WX and Traffic, Dual EI's (one Lightspeed & one SDS CPI)
RV-14A under construction.
Link to my build site:
https://ivankristensen.smugmug.com/B...ENTAL-aircraft
Old 03-09-2015, 07:03 PM
Default Dunnellon Fl. airport (X35) Fly-in.
Bill,
Are you still planning to come to the Fly-In at Jesse's this coming weekend?
Ivan Kristensen
Guelph, ON. Canada
Old 03-10-2015, 06:15 AM
Yes, as long as the weather permits.
Bill Peyton
RV-10 - 1125 hrs
N37CP
Old 03-10-2015, 07:48 AM
Palamedes's Avatar
Palamedes Palamedes is offline
Looks perfect.. The paint may have been tough but you nailed it.
Jason Ellis
RV-10 - Still pluggin away at it.
Blairsville, GA
Youtube Channel and RV-10 Build Log
Old 03-10-2015, 04:16 PM
togaflyer togaflyer is offline
Let us know after your night flight. I have looked at this light and also the AeroLed, which has come out with an led wing tip lights.
Old 03-10-2015, 06:58 PM
Will do! as soon as I get out at night
Bill Peyton
RV-10 - 1125 hrs
N37CP
