Pierre,
This fit is important. The mating parts or course come with the wing kit, but I believe you can order the doubler if you don't have the kit. Situation: once it is riiveted together, and in the plane, there is no changing it. Too loose, and the wing can even move a bit. Too tight, an the wings are very hard to install. I would make this a priority item. Easier to do now than later.
Bob
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
