Old 03-08-2015, 06:45 AM
mccartam mccartam is offline
Default Dimpled prior to deburring
New builder here, been lurking on the forums for awhile but finally settled on building the -7 and ordered the emp kit. I've hit what may be my first snag. During the process of preparing one of the HS702 spars I dimpled the 4 rivet holes that attach it to HS710 and HS714 without first deburring. My question is what to do about it? Do I call Vans and order a replacement, leave it as is and build on, attempt to debur after dimpling??
Old 03-08-2015, 07:02 AM
wirejock's Avatar
wirejock wirejock is offline
Default Welcome
Welcome Andrew
Take a close look at the holes with a magnifying glass. If you don't see any cracks, give the extruded dimple a rub with scotch brite or 400 grit and move on.
Personally, I would recommend building the VS first. If you do build the HS, check out the "Gotchas" thread on the "7" page. There are a few tricky spots.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 03-08-2015, 07:50 AM
DaleB's Avatar
DaleB DaleB is offline
Welcome to VAF, and don't panic. Debur and build on. If it were me, I'd start with a small piece of maroon Scotchbrite pad, twisted a few times on both sides of the hole. A regular deburring cutter might do just as well, just be careful. It doesn't take a lot.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 03-08-2015, 08:07 AM
Thanks for the replies. Saved by VAF!
Old 03-08-2015, 09:40 AM
SvingenB SvingenB is offline
I think it is much easier to debur too much than too little. There is no gain in deburring the shop head side for instance, other than just removing lose particles.
RV-4 #4520, Slow built
B Svingen
RV-4 Project Log
Onex Project Log
EAA Chapter 573 Norway
