Old 03-06-2015, 01:57 PM
rgbewley rgbewley is offline
Talking Which Governor Stud do you Need?
As a follow up to a previous thread:
Hartzell has modified the base of some of their governors for use with the longer studs. If you purchase a new governor from Van's with a prefix of "S", you will need long governor studs.
If you have an older Hartzell governor with a prefix of "V", "U" or "E", you will also need long studs.
If you have a PCU-5000 or MT governor - long studs.
Other Hartzell, Woodward, McCauley governors require the short studs.
Tell your engine builder, so they can change them for you!
Rhonda Barrett-Bewley
Old 03-06-2015, 02:00 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Thanks Rhonda-------good stuff to know.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-06-2015, 02:09 PM
Mike S's Avatar
Senior Curmudgeon
Rhonda, check your private messages.
Mike Starkey
VAF 909
Rv-10, N210LM.
