Go Back   VAF Forums > The Never Ending Debate Section > Tools
Old 03-03-2015, 10:22 AM
PilotRPI PilotRPI is offline
Default DRDT-2 Setup
I have a couple questions regarding the setup of the upper mounting bolts and the return spring.
1) Does the eye of the spring go over the black spacer, or should it be on the threads of the bolt between the bolt head and the spacer?
2) What do you do with the nut on the upper bolts? Do you make it tight toward the head of the mount bolt, or do you set it so there is a little space between the bolt head and the black spacer so that the return spring isn't squished (if that is indeed the proper spot for the return spring loop)?
I got my DRDT-2 second hand, and I noticed the dimples in my practice kit aren't 100% concentric, so I want to reassemble it.
Thanks!
Jesse
Old 03-03-2015, 12:20 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
1) Yes, over the spacer.
2) Put on the big washer, then nut, then black spacer, spring, then bolt. The nut is tightened tight, and the bolt has a little gap.
Pictures:
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 03-03-2015, 01:15 PM
John Tierney John Tierney is offline
Default Base Shim
You may also be able to adjust the base plate, where the bottom die is inserted, by loosening the screws and inserting folded sheets of aluminum foil in different spots as a shim to fine tune the dimple shape.
John Tierney
Vonore, TN
RV-7A - N777JT Flying
