RV-7. There is a T fitting on the cockpit side of the firewall that goes into the threaded opening on the bottom of the brake reservoir. The other 2 ends of the T accept the 2 shortest brake lines coming off the passenger brake master cylinders at the top of the 2 cylinders. Does it matter which line goes to which open spot on the T?
I usually take a picture or two before I disassemble anything but I blew it this time.
I had to swap a brake reservoir today. Do you have any idea how Hard it is to remove and reinstall bolts and nuts that go through the firewall when you are alone!? Cried a little I think.
