Old 02-27-2015, 08:01 AM
prkaye prkaye is offline
Default resistor for Dynon to P-Lead - chasis mount or through hole?
I need to order up a resistor to connect my Dynon tach input the Mag P-Lead.
SHould I go with a "Chasis mount" resistor, or a "Through hole" resistor?
http://www.digikey.ca/product-search...esistors/66696
http://www.digikey.ca/product-search...esistors/66690
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 02-27-2015, 08:10 AM
bruceh's Avatar
bruceh bruceh is offline
The "through hole" is what you want. You are not going to be mounting this to a circuit board, correct?
Bruce Hill
2020 VAF donator
Old 02-27-2015, 08:12 AM
krw5927 krw5927 is offline
As far as operation is concerned, it doesn't matter which you choose. The chassis mount will obviously weigh more. I elected to use a through-hole resistor, soldered in-line to the proper EMS wire with heat shrink covering for strain relief.
Kurt W.
RV9A
FLYING!!!
Old 02-27-2015, 08:36 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Using chassis mount high wattage wirewound resistors for this would be gross overkill. Small 1/4 watt inline axial lead resistors are all that's necessary. You may also find that values as high as 100k ohms or larger may be needed to get stable rpm readings, especially on the older D120 EMS system with Slick mags.
Neal Howard
Airplaneless once again...
Old 03-06-2015, 06:40 AM
The manual says you can use resistor values all the way up to 150kohm. What would be the effect of using a larger resistor value than necessary? Possible damage to components? Zero RPM reading? Lagging RPM readings?
Phil
RV9A (SB)
Ottawa, Canada
Old 03-06-2015, 06:49 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Too large a resistor value (Ohms) and you won't get any RPM indication.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 03-06-2015, 07:23 AM
For what it's worth, a 1/2 watt 30k through-hole resistor works perfectly on both my Slick 4370/4371 mags with Skyview.
Kurt W.
RV9A
FLYING!!!
Old 03-06-2015, 10:54 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default The larger you go
the slower the response on your readout --- I used 47s and they are fine -- Radio Shack did not have the 33s when I was looking.
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
