Go Back   VAF Forums > The Never Ending Debate Section > Primers
  #21
Old 09-23-2019, 04:37 PM
GPV GPV is offline
Thanks for the input guys. I'm going to have another go at it this weekend and will fiddle with the paint and mixture settings. I suspect my air pressure was too high as quite a few people have now suggested it is the first thing to check!
Thanks again,
Greg
Old 09-23-2019, 06:48 PM
I shot some other parts using the 1.8 mm tip and got a smoother finish. My overall impression is that Ekopoxy is a good product, as long as you can put up with the mixing hassles and can spray it within the humidity and temperature limits.
Also, I really like the PPS cup system. Although an aftermarket system, and not cheap, it's worth getting.
Dave
Old 10-06-2019, 07:18 AM
Jetmart Jetmart is online now
Originally Posted by Larry DeCamp View Post
I was told that the value of epoxy primer was its Corrosion resistance, not toughness. Ie. Two part finish coats are just as scratch resistant as epoxy. Not suggesting this, but I used the white single component primer and urethane gray on the interior and it is really tough. The primer is like milk, no mixing, you can save what you don't use for intermittent spray sessions.
Larry what manufacturer of white single component primer and urethane grey did you use?
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
Received RV-14 Empennage Kit October 22, 2019
Started Tail Cone Dec 2019
Received QB Kit April 2020
Finished a mounted Tail Surfaces to Fuselage June 2020
2020 Dues Paid
Old 10-06-2019, 07:50 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Stewart single component white primer
The single component primer with Ekopoly grey 2k finish has been very scratch resistant.
However, as I have warned many times, you must completely cover the primer with 2K material . ALL exposed edges or wicking paths TO the primer for solvents or mogas WILL soften and blister the finish coat.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
