View Poll Results: Oxygen Cylinder Valve Style
CGA-540 4 30.77%
CGA-870 7 53.85%
Other 2 15.38%
Multiple Choice Poll. Voters: 13. You may not vote on this poll
  #11
Old 02-24-2015, 03:52 PM
DarylT's Avatar
DarylT DarylT is offline
Default Yes Big Diff
Yes Brett it is a big difference.
Dive tanks are compressed air. Not pure Oxygen.
Oxygen we use for flying is compressed O2 pure Oxygen.
They only use Oxygen in diving for mixed gas diving. (Professionals very deep)
Daryl Tolliver
VAF 1086
Yes: I paid my =VAF= membership dues for 2020
RV-7A - N754RV: Status - Pink Slip is In! First Flight 8/23/12 - My First Flight 9/24/12!
Home from GloCustom for Paint! 3/16/13
957 hours and climbing
7th Condition Inspection complete 10/31/2019
Superior XP IO360 (180 HP), Hartzell Blended Airfoil, AF-5400 EFIS panel, Garmin Aera 660, TruTrak Vizion 385 AutoPilot, Dual Pmags
Houston, TX
Track: SPOT
Weiser Airpark (EYQ)
http://www.rv7a-factory.com
Old 02-24-2015, 05:51 PM
David_Nelson's Avatar
David_Nelson David_Nelson is offline
Default It's been decided ...
Wow - I was really hoping this was going to lean heavily to one side or the other but so far it hasn't. I understand it hasn't had much time to incubate (so much for folks checking VAF at work! ) but I need to allow time to ship and set the system up. To those that responded, Thank You! I learned some things and that's always good.
So what did I decide? I'm going the CGA-540 route.
Per Bill's post, I bought through Cramer Decker Medical. Their prices have changed a bit since Sept 2010:
  • Their D cylinder now goes for $58.95 (an increase of $20)
  • Their Low Profile CGA-540 w/ guage still goes for $30.00 (no price change)
  • Their AREG5404 0-4 LPM CGA-540 regulator now goes for $40.95 (an increase of $1)
/\/elson
RV-7A Tip-Up
NW Austin, TX
Old 02-24-2015, 07:37 PM
Greg Baron Greg Baron is offline
Default Oxygen system
Mountain High Oxygen systems utilizes CGA540. It is my understanding that the medical system is not really designed for vibration situations. I had a washer "combust" during a surgical procedure in my surgery center. Not a desirable situation. This should less of a threat with the industrial design.
Old 02-25-2015, 08:19 AM
flightlogic's Avatar
Default flow rate for RV flying
Do a search for pediatric regulators. They are about the same price you show... but have fractional LPM flow rates.
The 1-4 LPM flow will be too much... in my experience.
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
Old 02-25-2015, 08:33 AM
MarkW's Avatar
MarkW MarkW is offline
Yes Bret and DarylT,
Nitrox is a very common dive mix. Therefore all the dive shops in Florida carry pure O2. I do double check by watching them fill the tanks.
DarylT - Nitrox is a very common recreational dive mix used to allow more bottom time mostly in shallow and mid depth dives.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
